Текущее время: Сб, апр 27 2024, 18:31
 Заголовок сообщения: DMS, хранение оригиналов
СообщениеДобавлено: Пт, июл 18 2008, 16:37
Коллеги, добрый день!
Поскажите плиз, как настроить систему, чтобы прикрепляемые оригиналы к дмс-документу в транз cv01n, сохранялись в определенной папке на сервере SAP...
базиса нет:( сам бьюсь, то путь недоступен то еще что-нить:((((
СообщениеДобавлено: Пт, июл 18 2008, 22:19
Сб, сен 01 2007, 08:56
Сам не ставил. Но думаю если вы прочтете ссылки ниже и добавите пару строчек в транзакциях DC10, DC20, DC30, OAC0 - все должно заработать.
Note 1057932 - FAQ: Atachment transfer to backend, Required Configurations
Цитата для примера. Не обязательно так делать:
"What are the required settings to ensure the attachments are transferred to the R/3 Backend for Purchase Requistion and Purchase Order ?
Transaction DC10 :
You will need to maintain the document type that you are transferring. In case of attachment transfer from SRM system you will require to maintain the Doc Type as 'SRM'.
Transaction DC20 :
1.Click on the entry 'Define data carrier server, Frontends' on the left side of the screen.
2.On the right side you should have a data carrier type entry maintained 'PC'. The path for the same should be maintained as 'C:\temp'
3.Click on the entry 'Identify Frontend Computers'. Here you will
require to maintain an entry as default carrier type.
Transaction DC30 :
This transaction allows you to maintain the extension of file, you are trying to transfer eg: .DOC , .Xls.
The respective file formats needs to be maintained for each Application type defined
Please see for attachment of type doc you will require to maintain the workstation appl as 'DOC' as against 'WRD' which is usually maintained in the system.
SRM system transfers the type DOC as against the WRD and you will need to copy the WRD Appl type and edit the entry to DOC. Without this change the doc files cannot be opened in the backend.
For URL transfer of attachment, depending on the type of the document you are transferring you will require to maintain *.* in file format in DC30.
The configurations mentioned here are very explicit to SRM requirement.
For detailed configurations of Cross Application documents in R/3 please refer to the following link
http://help.sap.com/saphelp_47x200/help ... ameset.htm"
PS:
Thread: Error after attaching document thru CV01n
https://www.sdn.sap.com/irj/sdn/thread? ... ID=5456481
Thread: DC20
https://www.sdn.sap.com/irj/sdn/thread?threadID=951264
Thread: error while cheking the files.
https://www.sdn.sap.com/irj/sdn/thread? ... ID=5728680
Thread: Cheking in Originals to Content server using http
https://www.sdn.sap.com/irj/sdn/thread? ... ID=5660436
Thread: Hi DMS Chekin : Help Need (Urgent)
https://www.sdn.sap.com/irj/sdn/thread? ... ID=5753905
СообщениеДобавлено: Вт, авг 12 2008, 08:13
Вт, авг 12 2008, 07:40
Для этого существует SAP Content Server.
ай, каррамба
