RolandUlm написал(а):
Никакого эффекта, та же самая ошибка
a эту строку убрал?
sapmsCRI 3624/tcp # SAP System Messaging Service Port
кроме того, нота 52959 говорит:
Ask your R/3 System administrator for the "service" of the affected R/3
message server (sapms<SID>, SID: System-ID), of the affected R/3
dispatcher (sapdpxx) or of the affected SAP gateway (sapgwxx) and please
add the missing entry in the "services" file on your host:
(UNIX: /etc/services, NT: <windir>/system32/drivers/etc/services),
AS/400: WRKSRVTBLE)
The following are valid as defaults:
sapdp00 3200/tcp
sapdp99 3299/tcp
sapgw00 3300/tcp
sapgw99 3399/tcp
sapms<SID> starts from 3600/tcp.
IMPORTANT:
When inserting this into this file, pleas ensure that the last entry is
always terminated with a <return>. For some platforms, this may cause
problems, as the last entry may not be recognized.
Если это не работает, значит не в портах дело
