Текущее время: Чт, июн 06 2024, 10:58
 Заголовок сообщения: SAPGUI 7.3 Windows8
СообщениеДобавлено: Пн, окт 29 2012, 08:55
Вт, ноя 07 2006, 10:12
Всем привет, никто еще не пробовал? Работает ли гуя с восьмеркой?
С уважением, Р.В. Величко
 Заголовок сообщения: Re: SAPGUI 7.3 Windows8
СообщениеДобавлено: Пн, окт 29 2012, 10:29
Чт, июн 14 2012, 10:19
metha написал:
Официально работает
Note 66971
SAP GUI for Windows Release 7.30
Windows XP Professional 32bit - restricted support
Windows XP Professional 64bit edition on x64 (AMD) and Intel EM64T - restricted support
Windows 2003 Server 32bit - restricted support
Windows Server 2003 64bit edition on x64 (AMD) and Intel EM64T - restricted support
Windows 2003 R2 Server 32bit - restricted support
Windows Server 2003 R2 64bit edition on x64 (AMD) and Intel EM64T - restricted support
Windows Vista 32bit (only "Business", "Ultimate" and "Enterprise" editions) - restricted support
Windows Vista 64bit edition on x64 (AMD) and Intel EM64T (only "Business", "Ultimate" and "Enterprise" editions) - restricted support
Windows 2008 Server 32bit
Windows 2008 Server 64bit on x64 (AMD) and Intel EM64T
Windows 2008 R2 Server 64bit on x64 (AMD) and Intel EM64T
Windows 7 32bit (only "Professional", "Ultimate" and "Enterprise" editions)
Windows 7 64bit edition on x64 (AMD) and Intel EM64T (only "Professional", "Ultimate" and "Enterprise" editions)
Windows 8 32bit (only "Professional", "Ultimate" and "Enterprise" editions) - supported as of patchlevel 1 (please see chapter "SAP GUI for Windows on Windows 8" for restrictions)
Windows 8 64bit edition on x64 (AMD) and Intel EM64T (only "Professional", "Ultimate" and "Enterprise" editions) - supported as of patchlevel 1 (please see chapter "SAP GUI for Windows on Windows 8" for restrictions)
Windows Server 2012 64bit edition on x64 (AMD) and Intel EM64T (only "Professional", "Ultimate" and "Enterprise" editions) - planned (under evaluation)
Жизнь нужно прожить так, чтобы было стыдно рассказать, но приятно вспомнить!
http://sapadm.ru/
СообщениеДобавлено: Чт, ноя 08 2012, 11:55
Вт, апр 17 2007, 14:59
работает с win8 64 корпоративной, сам пробовал! )
СообщениеДобавлено: Пн, ноя 12 2012, 07:42
Официальной док-ции мало видно :)
http://sapadm.ru/
 Заголовок сообщения: Re: SAPGUI 7.3 Windows8  Тема решена
СообщениеДобавлено: Вт, ноя 13 2012, 13:48
Чт, май 12 2005, 11:10
Работает и на 7ке и на 8ке - глюков пока что не заметил.
СообщениеДобавлено: Пн, ноя 19 2012, 18:55
всем спс
СообщениеДобавлено: Вт, мар 18 2014, 06:56
Вт, мар 18 2014, 06:30
Помогите пожалуйста !!!
Sap logon 7.3 не может установить соединение с сервером в Windows8
Сервер пингуется, брандмауэр выключен, антивирусник выключен, UAC выключен.
Прописываю сервер, инстанцию, ID системы жму вход и появляется маленькое окошко соединение и на этом всё. Оставлял на сутки ничего не произошло ошибки не выдал.
Такое чувство что восьмёрка что-то где-то блокирует
Устанавливал тоже самое на семёрку - сработало без проблем.
PS. Если вбиваю не верный адрес сервера то сразу ошибка
Соединение с сервером у меня идёт через континент (не через интернет)
СообщениеДобавлено: Вт, мар 18 2014, 11:59
Пн, июн 27 2011, 08:25
1) попробуйте все-таки сменить интернет-канал, хотя бы для целей тестирования.
например, через мобильный, а лучше все-таки проводной интернет.
2) попробуйте подключиться к серверу через команду sapgui.exe, а не через окно.
3) а что мешает Вас собственно, снести sapgui 730 и установить ту версию, которая у Вас точно работала (работает) в другом месте.
4) ну и намёк на Win8:
:D
Сам Билл Гейтс решил снести Win8 и установить Win7.
http://www.newyorker.com/online/blogs/b ... ws-81.html
СообщениеДобавлено: Вт, мар 18 2014, 12:30
Я пробовал разные версии результат одинаков.
На моём компе есть интернет и прописан маршрут к континенту (в локалке).
Я так понимаю что SAP пытается найти сервер в интернете и поэтому соединение виснет.(я пробовал в браузере набрать адрес 10.12.?.?:8000 и всё останавливается на ожидание)
Где в SAP прописать чтобы он обратился по локалке а не в интернет??
СообщениеДобавлено: Вт, мар 18 2014, 13:20
Боюсь, это не в SAP.
А в таблице маршрутизации, в метрике.
СообщениеДобавлено: Вт, мар 18 2014, 14:07
Что может означать ошибка
SAP_CMINIT3 : rc=20 > Connect to SAP gateway failed
Connect_PM GWHOST=10.12.16.8, GWSERV=sapgw00, SYSNR=00
LOCATION CPIC (TCP/IP) on local host
ERROR partner '10.12.16.8:3300' not reached
TIME Tue Mar 18 16:51:17 2014
RELEASE 720
COMPONENT NI (network interface)
VERSION 40
RC -10
MODULE nixxi.cpp
LINE 3286
DETAIL NiPConnect2: 10.12.16.8:3300
SYSTEM CALL connect
ERRNO 10060
ERRNO TEXT WSAETIMEDOUT: Connection timed out
COUNTER 1
СообщениеДобавлено: Сб, мар 22 2014, 00:21
Информация, предоставленная Вами, говорит о:
1) у Вас не 730, а 720.
В связи с этим для Win8 постарайтесь установить все-таки последнюю версию с последними патчами.
2) номер системы точно должен быть 00 ?
3) скорее всего, у Вас нет записи, подобной
sapgw00  3300/tcp
sapgw01  3301/tcp
в файле services (расположен в пути типа C:\Windows\System32\drivers\etc\services на ПК).
4) возможно, не пингуется 10.12.16.8 - если не пингуется - поднимайте сетку.
 Заголовок сообщения: SAPGUI 7 3 Windows8
СообщениеДобавлено: Пн, мар 07 2016, 08:53
Вс, мар 06 2016, 20:09
Добрый день,
А у Вас точно Windows 7 64-х битная? Может быть у Вас 32-х битная версия, требующая соответствующего драйвера?
Котов Алексей,
Копия-Москва.
